Ir para o conteúdo principal
Lenovo G50-80 80E5 Fan Replacement
O que você precisa
  1. Lenovo G50-80 80E5 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Fan Replacement: passo 2, imagem 1 %32 Lenovo G50-80 80E5 Fan Replacement: passo 2, imagem 2 %32 Lenovo G50-80 80E5 Fan Replacement: passo 2, imagem 3 %32
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Fan Replacement: passo 3, imagem 1 %32 Lenovo G50-80 80E5 Fan Replacement: passo 3, imagem 2 %32 Lenovo G50-80 80E5 Fan Replacement: passo 3, imagem 3 %32
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Fan Replacement: passo 4, imagem 1 %32 Lenovo G50-80 80E5 Fan Replacement: passo 4, imagem 2 %32 Lenovo G50-80 80E5 Fan Replacement: passo 4, imagem 3 %32
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: passo 5, imagem 1 %32 Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: passo 5, imagem 2 %32
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Fan Replacement: passo 6, imagem 1 %32 Lenovo G50-80 80E5 Fan Replacement: passo 6, imagem 2 %32
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Fan Replacement, Fan: passo 7, imagem 1 %32
    • Rotate the laptop so that you are positioned over the fan.
  8. Lenovo G50-80 80E5 Fan Replacement: passo 8, imagem 1 %32
    • Remove the three 6 mm screws securing the fan using a Phillips #00 screwdriver.
  9. Lenovo G50-80 80E5 Fan Replacement: passo 9, imagem 1 %32
    • Unplug the cable from the tri-color end connected to the motherboard.
  10. Lenovo G50-80 80E5 Fan Replacement: passo 10, imagem 1 %32
    • Remove the fan from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 517
