Ir para o conteúdo principal
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: passo 2, imagem 1 %32 Lenovo G50-80 80E5 Battery Replacement: passo 2, imagem 2 %32 Lenovo G50-80 80E5 Battery Replacement: passo 2, imagem 3 %32
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: passo 3, imagem 1 %32 Lenovo G50-80 80E5 Battery Replacement: passo 3, imagem 2 %32 Lenovo G50-80 80E5 Battery Replacement: passo 3, imagem 3 %32
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: passo 4, imagem 1 %32 Lenovo G50-80 80E5 Battery Replacement: passo 4, imagem 2 %32 Lenovo G50-80 80E5 Battery Replacement: passo 4, imagem 3 %32
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
Conclusão
4 outras pessoas executaram este guia.
Abigail Hood
Membro desde: 10/17/17
387 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G6, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G6
Membros da 4
Autoria de 10 guias
Um comentário
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 4,587
