Ir para o conteúdo principal
Lenovo G40-30 LCD Screen Replacement
O que você precisa
  1. Lenovo G40-30 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement, Battery: passo 1, imagem 2 %32 Lenovo G40-30 LCD Screen Replacement, Battery: passo 1, imagem 3 %32
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: passo 2, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement: passo 2, imagem 2 %32 Lenovo G40-30 LCD Screen Replacement: passo 2, imagem 3 %32
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: passo 3, imagem 1 %32
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: passo 5, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement: passo 5, imagem 2 %32
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: passo 6, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement: passo 6, imagem 2 %32 Lenovo G40-30 LCD Screen Replacement: passo 6, imagem 3 %32
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: passo 7, imagem 1 %32 Lenovo G40-30 LCD Screen Replacement: passo 7, imagem 2 %32
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: passo 8, imagem 1 %32
    • Now you have removed the screen and are ready to install a new one.
Conclusão
Jimmy McClenan
Membro desde: 02/08/18
156 Reputação
Autoria de 1 guia
Equipe
2 comentários
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Responder
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 19
Duração total: 2,468
