Ir para o conteúdo principal
Lenovo Flex 6-11IGM Trackpad Replacement
O que você precisa
  1. Lenovo Flex 6-11IGM Trackpad Replacement, Back Panel: passo 1, imagem 1 %32
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Trackpad Replacement: passo 2, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 2, imagem 2 %32
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Trackpad Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Trackpad Replacement: passo 4, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 4, imagem 2 %32
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Trackpad Replacement, Battery: passo 5, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement, Battery: passo 5, imagem 2 %32
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Trackpad Replacement: passo 6, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 6, imagem 2 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 6, imagem 3 %32
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Trackpad Replacement: passo 7, imagem 1 %32
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: passo 8, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: passo 8, imagem 2 %32
    • Remove the connecting wire labelled "TP" by lifting the tab with the opening tool.
  9. Lenovo Flex 6-11IGM Trackpad Replacement: passo 9, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 9, imagem 2 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 9, imagem 3 %32
    • Disconnect the keyboard ribbon from the motherboard by lifting the black tab and pulling the ribbon out with the opening tool.
  10. Lenovo Flex 6-11IGM Trackpad Replacement: passo 10, imagem 1 %32
    • Pull up the black safety tape.
  11. Lenovo Flex 6-11IGM Trackpad Replacement: passo 11, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 11, imagem 2 %32
    • Remove the three silver 2.3 mm Phillips #00 screws.
    • The third one is under the black tape.
  12. Lenovo Flex 6-11IGM Trackpad Replacement: passo 12, imagem 1 %32 Lenovo Flex 6-11IGM Trackpad Replacement: passo 12, imagem 2 %32
    • Slide the trackpad up from its seat using the opening tool and remove it.
Conclusão
Rie Kuraoka
Membro desde: 01/23/20
886 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S7-G10, Paton Spring 2020 Membro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
Membros da 2
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 310
