Ir para o conteúdo principal
Lenovo Flex 6-11IGM Heat Sink Replacement
O que você precisa
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: passo 1, imagem 1 %32
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 2, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 2, imagem 2 %32
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 4, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 4, imagem 2 %32
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: passo 5, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: passo 5, imagem 2 %32
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, imagem 2 %32 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, imagem 3 %32
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 7, imagem 1 %32
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, imagem 2 %32 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, imagem 3 %32
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 9, imagem 1 %32 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 9, imagem 2 %32
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Conclusão
Rie Kuraoka
Membro desde: 01/23/20
913 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S7-G10, Paton Spring 2020 Membro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
Membros da 2
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 306
