Ir para o conteúdo principal
Lenovo Flex 3-1120 Speakers Replacement
O que você precisa
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: passo 2, imagem 1 %32 Lenovo Flex 3-1120 Speakers Replacement: passo 2, imagem 2 %32
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: passo 4, imagem 1 %32
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: passo 6, imagem 1 %32 Lenovo Flex 3-1120 Speakers Replacement: passo 6, imagem 2 %32
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: passo 7, imagem 1 %32 Lenovo Flex 3-1120 Speakers Replacement: passo 7, imagem 2 %32
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: passo 8, imagem 1 %32
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Conclusão
Geoff Bentz
Membro desde: 03/09/16
934 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 421
