Ir para o conteúdo principal
Lenovo Flex 3-1120 Network Card Replacement
O que você precisa
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: passo 2, imagem 1 %32 Lenovo Flex 3-1120 Network Card Replacement: passo 2, imagem 2 %32
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: passo 4, imagem 1 %32
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: passo 5, imagem 1 %32
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: passo 6, imagem 1 %32 Lenovo Flex 3-1120 Network Card Replacement: passo 6, imagem 2 %32
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: passo 7, imagem 1 %32
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: passo 8, imagem 1 %32 Lenovo Flex 3-1120 Network Card Replacement: passo 8, imagem 2 %32
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
Conclusão
Geoff Bentz
Membro desde: 03/09/16
934 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
Membros da 4
Autoria de 7 guias
Um comentário
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 815
