Ir para o conteúdo principal
Lenovo Flex 3-1120 Hard Drive Replacement
O que você precisa
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo Flex 3-1120 Hard Drive Replacement: passo 2, imagem 2 %32
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: passo 6, imagem 1 %32 Lenovo Flex 3-1120 Hard Drive Replacement: passo 6, imagem 2 %32
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: passo 7, imagem 1 %32
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: passo 8, imagem 1 %32
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: passo 9, imagem 1 %32
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: passo 10, imagem 1 %32
    • Lift the hard drive out from the computer.
Conclusão
7 outras pessoas executaram este guia.
Geoff Bentz
Membro desde: 03/09/16
934 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
Membros da 4
Autoria de 7 guias
4 comentários
How do you reload operating system.... for example windows 10?
supermac200 - Responder
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Responder
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Responder
That sata connector is the worst thing ever
dilleremail - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 36
Duração total: 10,889
