Ir para o conteúdo principal
Lenovo Flex 3-1120 Battery Replacement
O que você precisa
  1. Lenovo Flex 3-1120 Battery Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Battery Replacement: passo 2, imagem 1 %32 Lenovo Flex 3-1120 Battery Replacement: passo 2, imagem 2 %32
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Battery Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Battery Replacement: passo 4, imagem 1 %32
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Locate the black battery on the bottom right of the computer.
  6. Lenovo Flex 3-1120 Battery Replacement: passo 6, imagem 1 %32 Lenovo Flex 3-1120 Battery Replacement: passo 6, imagem 2 %32
    • Locate the six 3.5mm Phillips head screws along the edges of the battery.
    • Remove all six of the screws using a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Battery Replacement: passo 7, imagem 1 %32 Lenovo Flex 3-1120 Battery Replacement: passo 7, imagem 2 %32
    • Locate the multicolored power cables coming directly from the top of the battery and into the motherboard.
    • Use a spudger to slide the power cables down and away from its port on the motherboard.
  8. Lenovo Flex 3-1120 Battery Replacement: passo 8, imagem 1 %32
    • Lift the battery out from the computer.
Conclusão
4 outras pessoas executaram este guia.
Geoff Bentz
Membro desde: 03/09/16
934 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-1, Catania Spring 2016
UMASSD-CATANIA-S16S7G1
Membros da 4
Autoria de 7 guias
3 comentários
I lifted the battery out from the computer twice. Now what? I used the spudger and I can't bloody well remove screws that are already removed, can I? Reverse order my eye! Then I caught my dick in the fan. These instructions are impossibly difficult! Thanks a lot!!
Weird Fran - Responder
Where do you purchase a replacement battery? And just what is a spudger anyway? It is not on your list of things to purchase so where do I get one?
Jeff Van Hoy - Responder
You don’t really need a spudger. A guitar pick or even a flathead screwdriver (if you’re careful) can work, although in my personal experience just being careful while prying it out is perfectly fine. It’s used so you don’t rip off the little plastic clips that hold the bottom chassis together.
watercannons -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 9,915
