Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over so the bottom is facing upwards.
Remove all nine 6mm Phillips #0 screws located along the edges and in the centre of the back panel.
Using a prying tool, carefully lift up the keyboard.
Remove all four 3.5 mm Phillips screws underneath the keyboard.
Separate the top and bottom panels of the laptop using a prying tool.
Slide the prying tool along the edges of the laptop until the bottom panel is completely separated.
Remove the back cover of the laptop once you have finished prying it open.
Remove the two 4 mm Phillips screws holding the hard drive adapter in place.
Take out the adapter containing the hard drive from the laptop.
Remove all four 4mm Phillips screws from the adapter.
Remove the hard drive from the adapter.
Insert the new hard drive into the adapter.
Put all four 4mm Phillips screws back into the adapter with the hard drive, in order to hold it in place.
Put the adapter back in and reassemble the laptop.
