Ir para o conteúdo principal
Lenovo Flex 2-14 Hard Drive Replacement
O que você precisa
  1. Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: passo 1, imagem 3 %32
    • Make sure your laptop is off before you begin.
    • Flip the laptop over so the bottom is facing upwards.
    • Remove all nine 6mm Phillips #0 screws located along the edges and in the centre of the back panel.
  2. Lenovo Flex 2-14 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 2, imagem 2 %32
    • Using a prying tool, carefully lift up the keyboard.
  3. Lenovo Flex 2-14 Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 3, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 3, imagem 3 %32
    • Take out the keyboard by disconnecting the cable.
  4. Lenovo Flex 2-14 Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove all four 3.5 mm Phillips screws underneath the keyboard.
  5. Lenovo Flex 2-14 Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 5, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 5, imagem 3 %32
    • Separate the top and bottom panels of the laptop using a prying tool.
    • Slide the prying tool along the edges of the laptop until the bottom panel is completely separated.
    • Remove the back cover of the laptop once you have finished prying it open.
  6. Lenovo Flex 2-14 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the two 4 mm Phillips screws holding the hard drive adapter in place.
  7. Lenovo Flex 2-14 Hard Drive Replacement: passo 7, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 7, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 7, imagem 3 %32
    • Take out the adapter containing the hard drive from the laptop.
    • Remove all four 4mm Phillips screws from the adapter.
  8. Lenovo Flex 2-14 Hard Drive Replacement: passo 8, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 8, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 8, imagem 3 %32
    • Remove the hard drive from the adapter.
    • Insert the new hard drive into the adapter.
  9. Lenovo Flex 2-14 Hard Drive Replacement: passo 9, imagem 1 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 9, imagem 2 %32 Lenovo Flex 2-14 Hard Drive Replacement: passo 9, imagem 3 %32
    • Put all four 4mm Phillips screws back into the adapter with the hard drive, in order to hold it in place.
    • Put the adapter back in and reassemble the laptop.
    • Before reassembling, make sure the hard drive is securely in the case.
Conclusão
3 outras pessoas executaram este guia.
Eva Beilin
Membro desde: 05/10/20
250 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 47
Duração total: 3,973
