Ir para o conteúdo principal
Lenovo Essential G570 Keyboard Replacement
O que você precisa
  1. Lenovo Essential G570 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Keyboard Replacement: passo 2, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 2, imagem 2 %32
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Keyboard Replacement: passo 3, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 3, imagem 2 %32
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Keyboard Replacement, Back Panel: passo 4, imagem 1 %32
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Keyboard Replacement: passo 5, imagem 1 %32
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 2 %32 Lenovo Essential G570 Keyboard Replacement: passo 6, imagem 3 %32
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Remove the two 9mm Phillips #0 screws.
    • Remove the single 5mm Phillips #0 screw.
    • All 3 screws are located next to keyboard icons.
  8. Lenovo Essential G570 Keyboard Replacement: passo 8, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 8, imagem 2 %32
    • Flip the computer over and open it.
    • Using the plastic opening tool, pry open the top of the keyboard.
  9. Lenovo Essential G570 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
    • Be careful lifting the keyboard up because there is a delicate ribbon cable connected to the bottom.
  10. Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 1 %32 Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 2 %32 Lenovo Essential G570 Keyboard Replacement: passo 10, imagem 3 %32
    • While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
    • Carefully pull away the ribbon cable to detach it from the motherboard.
    • Be careful when unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
Conclusão
4 outras pessoas executaram este guia.
Nina Francisco
Membro desde: 03/01/18
385 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 2,424
