Ir para o conteúdo principal
Lenovo Essential G570 Back Panel Replacement
O que você precisa
  1. Lenovo Essential G570 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn the laptop over so that the bottom side is facing up.
  2. Lenovo Essential G570 Back Panel Replacement: passo 2, imagem 1 %32
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  3. Lenovo Essential G570 Back Panel Replacement: passo 3, imagem 1 %32 Lenovo Essential G570 Back Panel Replacement: passo 3, imagem 2 %32 Lenovo Essential G570 Back Panel Replacement: passo 3, imagem 3 %32
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
Conclusão
3 outras pessoas executaram este guia.
Justin Bickford
Membro desde: 03/01/18
446 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,520
