Pular para o conteúdo principal
Introdução
Use this guide to replace the RAM sticks in the Lenovo Essential G555-0873. The RAM sticks are clipped in and don’t require a tool for replacement.
Peças
Nenhum componente especificado.
  1. Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lift from the notch until the back panel comes up.
    • Lift from the notch until the back panel comes up.
  3. Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle. Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle. Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle.
    • Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Pull the RAM stick out of its socket.
    • Pull the RAM stick out of its socket.
  6. Push apart hinges of lower RAM stick until it pops up to a similar angle.
    • Push apart hinges of lower RAM stick until it pops up to a similar angle.
  7. Pull out second RAM stick in the same way as the first.
    • Pull out second RAM stick in the same way as the first.
  8. Push RAM sticks in diagonally, then push down and snap it in with hinges. Make sure that the RAM stick is aligned with the notch on the port when inserting it.
    • Push RAM sticks in diagonally, then push down and snap it in with hinges.
    • Make sure that the RAM stick is aligned with the notch on the port when inserting it.
Conclusão
Uma outra pessoa concluiu este guia.
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 38
