Ir para o conteúdo principal
Lenovo Essential G555-0873 Heat Sink Replacement
O que você precisa
  1. Lenovo Essential G555-0873 Heat Sink Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 Heat Sink Replacement: passo 2, imagem 1 %32
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 Heat Sink Replacement, Fan: passo 3, imagem 1 %32
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 Heat Sink Replacement: passo 4, imagem 1 %32
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 Heat Sink Replacement: passo 5, imagem 1 %32
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 Heat Sink Replacement, Heat Sink: passo 6, imagem 1 %32
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 Heat Sink Replacement: passo 7, imagem 1 %32 Lenovo Essential G555-0873 Heat Sink Replacement: passo 7, imagem 2 %32
    • Pull the heat sink assembly out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 145
