Ir para o conteúdo principal
Introdução
Removing the battery doesn't require any equipment, and does not have any steps that need to be completed prior to beginning the battery's removal. The battery may need to be replaced if the battery is too old and has expired. Use this guide to replace the battery in the Lenovo Essential G555-0873.
  1. Locate the switches on the bottom of the computer on either side of the battery, as shown in the picture.
    • Locate the switches on the bottom of the computer on either side of the battery, as shown in the picture.
  2. Push the switch on the right to the “unlock” position. There will be an audible click.
    • Push the switch on the right to the “unlock” position. There will be an audible click.
  3. Push and hold the switch on the left to its “unlock” position.
    • Push and hold the switch on the left to its “unlock” position.
  4. While still holding the switch on the left in the unlock position, slide the battery out. While still holding the switch on the left in the unlock position, slide the battery out.
    • While still holding the switch on the left in the unlock position, slide the battery out.
Conclusão
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 65
