Introdução
This guide will show you how to replace the screen on a Lenovo ThinkPad Edge E431 laptop.
O que você precisa
Remove the 2mm Phillips #00 screw from the battery cover.
Lift the battery cover out of its slot.
Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
3 outras pessoas executaram este guia.
