Introdução
This is a step by step guide on how to remove the fan assembly on the Lenovo Thinkpad Edge E431.
O que você precisa
Close the device and remove all power cables.
Lay the laptop flat with the bottom facing upwards.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the nine 2mm Phillips screws from the cooling assembly.
Using the tweezers, remove the fan power cable from the motherboard.
Uma outra pessoa concluiu este guia.
