Ir para o conteúdo principal
Lenovo Edge 2-1580 Storage Replacement
O que você precisa
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: passo 1, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement, Battery: passo 1, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: passo 2, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: passo 3, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement: passo 3, imagem 2 %32 Lenovo Edge 2-1580 Storage Replacement: passo 3, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: passo 4, imagem 1 %32
    • Pull the battery outward and remove it from the rest of the laptop.
    The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
    seattlehudson - Responder
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: passo 5, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement, Hard drive: passo 5, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: passo 6, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement: passo 6, imagem 2 %32
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
    The hard drive can also be slid backward from the connection. Then the clips will clear and can be easily lifted out. Additionally, it disconnects the hard drive at the same time. This also keeps from possibly breaking the clips or damaging the drive by prying.
  7. Lenovo Edge 2-1580 Storage Replacement: passo 7, imagem 1 %32 Lenovo Edge 2-1580 Storage Replacement: passo 7, imagem 2 %32
    • Carefully, using your hand, remove the hard drive from the laptop.
Conclusão
5 outras pessoas executaram este guia.
Julian Escallon
Membro desde: 09/27/17
714 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S14-G1, Boczar Fall 2017 Membro de USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
Membros da 4
Autoria de 5 guias
3 comentários
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - Responder
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 4,078
