Introdução
The guide will show you how to remove the storage hard drive unit that comes with the laptop. It is compatible with any 2.5" storage solutions like a SSD or HDD.
O que você precisa
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
5 outras pessoas executaram este guia.
3 comentários
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
Thank you, was looking everywhere to find that out!!!
Thank you, your help was so useful.
