Introdução
This guide will show you how to remove and replace the fan cooling solution of the laptop if for some reason it has become faulty and needs replacement.
O que você precisa
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Pull the battery outward and remove it from the rest of the laptop.
The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
2 comentários
Where can one find this fan?
