Ir para o conteúdo principal
Lenovo Edge 15 Wireless LAN Card Replacement
O que você precisa
  1. Lenovo Edge 15 Wireless LAN Card Replacement, Wireless LAN Card: passo 1, imagem 1 %32
    • With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
  2. Lenovo Edge 15 Wireless LAN Card Replacement: passo 2, imagem 1 %32
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Wireless LAN Card Replacement: passo 3, imagem 1 %32
    • Remove single 3mm screw holding down the end of the card using a Phillips #1 screwdriver.
  4. Lenovo Edge 15 Wireless LAN Card Replacement: passo 4, imagem 1 %32 Lenovo Edge 15 Wireless LAN Card Replacement: passo 4, imagem 2 %32
    • Use hands to disconnect card from slot and remove both cables.
    • When replacing connectors be sure to reconnect to proper terminal. Do this by orienting as is in the picture and attaching black cable to left side and white cable to right side.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure that connectors are in proper position as shown in step 3.
ryan sanders
Membro desde: 09/27/17
374 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S8-G1, Banghart Fall 2017 Membro de Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 53
Ao todo: 1,762
