Ir para o conteúdo principal
Lenovo Edge 15 Hard Drive Disk Replacement
O que você precisa
  1. Lenovo Edge 15 Hard Drive Disk Replacement, Battery: passo 1, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement, Battery: passo 1, imagem 2 %32
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Hard Drive Disk Replacement: passo 2, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 2, imagem 2 %32
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Hard Drive Disk Replacement: passo 3, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 3, imagem 2 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 3, imagem 3 %32
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Hard Drive Disk Replacement: passo 4, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 4, imagem 2 %32
    • Gently lift all four corners of the battery to remove it from the laptop.
  5. Lenovo Edge 15 Hard Drive Disk Replacement, Hard Drive Disk: passo 5, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement, Hard Drive Disk: passo 5, imagem 2 %32
    • Set the battery aside. This will allow easier access to the connector for the HDD.
    • Keep the batches of screws from the battery, HDD, case and cover plate separate. Although the screws may look similar, they have slightly different lengths and thread pitches for the different components.
  6. Lenovo Edge 15 Hard Drive Disk Replacement: passo 6, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 6, imagem 2 %32
    • The right side speaker can be lifted up off of its mounts and set out of the way if desired, but don't put sharp bends in the speaker wires.
  7. Lenovo Edge 15 Hard Drive Disk Replacement: passo 7, imagem 1 %32
    • With the Phillips #0 screwdriver, remove the 4 M2 x 4.0mm screws holding the HDD case to the laptop body.
  8. Lenovo Edge 15 Hard Drive Disk Replacement: passo 8, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 8, imagem 2 %32
    • Lift the HDD case up, and gently pull at the sides of the connector to disconnect it.
  9. Lenovo Edge 15 Hard Drive Disk Replacement: passo 9, imagem 1 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 9, imagem 2 %32 Lenovo Edge 15 Hard Drive Disk Replacement: passo 9, imagem 3 %32
    • With the Phillips #1, remove the 4 M3 x 4.0mm screws on the sides of the case.
    • The hard drive can now be removed.
Conclusão
During assembly, take careful note of the following items:
1) Keep track of the correct screws for each application.
2) Components may need to be wiggled to allow for proper screw alignment.
3) Don’t force screws in to avoid cross-threading.
4) Ensure proper connector alignment when reconnecting the HDD and battery cables.
Again, here is a video to help install a Windows OS on your new HDD: https://www.youtube.com/watch?v=tjmRWFep...
3 outras pessoas executaram este guia.
David Daley
Membro desde: 09/27/17
236 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S8-G1, Banghart Fall 2017 Membro de Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 41
Duração total: 6,217
