Ir para o conteúdo principal
Lenovo B575-1450 RAM Replacement
O que você precisa
  1. Lenovo B575-1450 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 RAM Replacement: passo 2, imagem 1 %32 Lenovo B575-1450 RAM Replacement: passo 2, imagem 2 %32
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 RAM Replacement: passo 3, imagem 1 %32 Lenovo B575-1450 RAM Replacement: passo 3, imagem 2 %32 Lenovo B575-1450 RAM Replacement: passo 3, imagem 3 %32
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 RAM Replacement, Back Panel: passo 4, imagem 1 %32 Lenovo B575-1450 RAM Replacement, Back Panel: passo 4, imagem 2 %32
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 RAM Replacement: passo 5, imagem 1 %32
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 RAM Replacement: passo 6, imagem 1 %32
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 RAM Replacement, RAM: passo 7, imagem 1 %32 Lenovo B575-1450 RAM Replacement, RAM: passo 7, imagem 2 %32
    • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
    • Pull the RAM out from the slot.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,260
