Ir para o conteúdo principal
Lenovo B575-1450 Display Panel Replacement
O que você precisa
  1. Lenovo B575-1450 Display Panel  Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Display Panel  Replacement: passo 2, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 2, imagem 2 %32
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Display Panel  Replacement: passo 3, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 3, imagem 2 %32 Lenovo B575-1450 Display Panel  Replacement: passo 3, imagem 3 %32
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Display Panel  Replacement, Display Panel: passo 4, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement, Display Panel: passo 4, imagem 2 %32
    • Remove both screw covers from the bottom of screen bezel using a plastic spudger. The screws underneath will now be exposed
  5. Lenovo B575-1450 Display Panel  Replacement: passo 5, imagem 1 %32
    • Using the Phillips #0 Screwdriver, remove the two 4.3 mm screws holding the display to the front bezel.
  6. Lenovo B575-1450 Display Panel  Replacement: passo 6, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 6, imagem 2 %32
    • Separate the front bezel from the display panel using the plastic opening tool by gently prying around the edges and removing it.
  7. Lenovo B575-1450 Display Panel  Replacement: passo 7, imagem 1 %32
    • Using the tweezers carefully disconnect the ZIF connector by pulling cable away from front facing camera that is attached to the back bezel.
  8. Lenovo B575-1450 Display Panel  Replacement: passo 8, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 8, imagem 2 %32 Lenovo B575-1450 Display Panel  Replacement: passo 8, imagem 3 %32
    • Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
    • There are two screws in the bottom left and right corners of the frame.
  9. Lenovo B575-1450 Display Panel  Replacement: passo 9, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 9, imagem 2 %32
    • Using the Phillips #0 Screwdriver, remove the four 2.9 mm screws from each side of the bracket that holds the display panel in place.
  10. Lenovo B575-1450 Display Panel  Replacement: passo 10, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 10, imagem 2 %32
    • Lay display panel face down on the keyboard.
    • Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
    • Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
  11. Lenovo B575-1450 Display Panel  Replacement: passo 11, imagem 1 %32 Lenovo B575-1450 Display Panel  Replacement: passo 11, imagem 2 %32
    • Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
    • Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
    • Pull up on flat wire until display is completely disconnected.
    • Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 1,401
