Introdução
The CD-ROM drive is fairly easy to locate and replace if it is no longer working.
O que você precisa
Turn off the computer.
Disconnect the charger from the computer.
Flip the computer upside down.
Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
Quase terminado!
Conclusão
