Ir para o conteúdo principal
Lenovo A7-50 A3500 Battery Replacement
O que você precisa
  1. Lenovo A7-50 A3500 Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo A7-50 A3500 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove SD and SIM card from device
  2. Lenovo A7-50 A3500 Battery Replacement: passo 2, imagem 1 %32
    • Remove screw with a simple coss screwdriver
  3. Lenovo A7-50 A3500 Battery Replacement: passo 3, imagem 1 %32 Lenovo A7-50 A3500 Battery Replacement: passo 3, imagem 2 %32 Lenovo A7-50 A3500 Battery Replacement: passo 3, imagem 3 %32
    • Remove cover. Starting from the point where you removed the screw.
    • Disassemble cover clockwise.
  4. Lenovo A7-50 A3500 Battery Replacement: passo 4, imagem 1 %32 Lenovo A7-50 A3500 Battery Replacement: passo 4, imagem 2 %32
    • Remove screw with simple screw driver
    • Remove metal holder as shown in picture
  5. Lenovo A7-50 A3500 Battery Replacement: passo 5, imagem 1 %32
    • Remove connection cable as shown.
  6. Lenovo A7-50 A3500 Battery Replacement: passo 6, imagem 1 %32
    • Disassemble battery pack. This might require a bit of pressure as it is glued
Conclusão
4 outras pessoas executaram este guia.
Stefan K
Membro desde: 01/13/18
469 Reputação
Autoria de 2 guias
Um comentário
Hi my tablet is similar to this
So the problem with my tablet is water went in. It does charge but it refuses to turn in, so I was trying to look for the reset pin hole but I can't find it on the tablet. Do you know how it can be fixed?
Blessing Bepe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 2,669
