Ir para o conteúdo principal
Lenovo A7-40, A7-50 A3500 Factory Reset
O que você precisa
Vídeo de Apresentação
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, imagem 1 %32 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, imagem 2 %32 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, imagem 3 %32
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, imagem 1 %32 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, imagem 2 %32 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, imagem 3 %32
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
Conclusão
33 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.182 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.519 guias
17 comentários
Is it applicable to my lenovo a516?
valvinzon - Responder
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 119
Duração total: 106,106
