Ir para o conteúdo principal
Lenovo 300e Chromebook USB and Charging Ports Replacement
O que você precisa
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, imagem 1 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, imagem 2 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, imagem 3 %32
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, imagem 1 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, imagem 2 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, imagem 3 %32
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, imagem 1 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, imagem 2 %32 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, imagem 3 %32
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 47
Duração total: 1,535
