Ir para o conteúdo principal
Lenovo 300e Chromebook Motherboard Replacement
O que você precisa
  1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Motherboard  Replacement: passo 2, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 2, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 2, imagem 3 %32
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Motherboard  Replacement, Battery: passo 3, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement, Battery: passo 3, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement, Battery: passo 3, imagem 3 %32
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Motherboard  Replacement: passo 4, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 4, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 4, imagem 3 %32
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: passo 5, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove the three silver 3 mm screws from the center of the metal cover using a Phillips #00 screwdriver.
  6. Lenovo 300e Chromebook Motherboard  Replacement: passo 6, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 6, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 6, imagem 3 %32
    • Remove two 3 mm screws from the top of the metal cover using a Phillips #2 screwdriver.
    • Remove the metal cover from the laptop.
  7. Lenovo 300e Chromebook Motherboard  Replacement: passo 7, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 7, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 7, imagem 3 %32
    • Remove the nine 3 mm screws from the motherboard using a Phillips #2 screwdriver.
    • Detach all the connectors from the motherboard.
  8. Lenovo 300e Chromebook Motherboard  Replacement: passo 8, imagem 1 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 8, imagem 2 %32 Lenovo 300e Chromebook Motherboard  Replacement: passo 8, imagem 3 %32
    • Remove the tape using a spudger.
    • Disconnect the large cable connector.
    • Remove the motherboard from the laptop.
Conclusão
Um comentário
where is the write protect screw located im trying to install windows on this model
Harvey Willis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 39
Duração total: 1,333
