Ir para o conteúdo principal
Lenovo 300e Chromebook Left and Right Click Buttons Replacement
O que você precisa
  1. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, imagem 3 %32
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, imagem 3 %32
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, imagem 3 %32
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, imagem 3 %32
    • Disconnect the metallic electrical tape by gently pulling back away from the keypad.
  6. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 6, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 6, imagem 2 %32
    • Remove two 5 mm screws from the metal plate using a Phillips #2 screwdriver.
  7. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, imagem 1 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, imagem 2 %32 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, imagem 3 %32
    • Remove the left and right click buttons from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 283
