Ir para o conteúdo principal
Lenovo 100s Chromebook-11IBY Webcam Replacement
O que você precisa
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: passo 1, imagem 1 %32
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 3, imagem 1 %32 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 3, imagem 2 %32
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 4, imagem 1 %32 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 5, imagem 1 %32
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 6, imagem 1 %32 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Conclusão
Milton Perez
Membro desde: 03/09/17
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 344
