Ir para o conteúdo principal
Lenovo 100s Chromebook-11IBY Speaker Replacement
O que você precisa
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: passo 1, imagem 1 %32
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 2, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 3, imagem 1 %32 Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 3, imagem 2 %32
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 4, imagem 1 %32 Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 4, imagem 2 %32 Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 4, imagem 3 %32
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 5, imagem 1 %32
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 6, imagem 1 %32 Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 6, imagem 2 %32
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: passo 7, imagem 1 %32
    • Repeat steps 5 & 6 in order to remove the right speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Milton Perez
Membro desde: 03/09/17
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 519
