Ir para o conteúdo principal
Lenovo 100s Chromebook-11IBY Screen Replacement
O que você precisa
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: passo 1, imagem 1 %32
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 3, imagem 1 %32 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 3, imagem 2 %32
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 4, imagem 1 %32
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 5, imagem 1 %32 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 5, imagem 2 %32
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 6, imagem 1 %32
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 7, imagem 1 %32
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 8, imagem 1 %32
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 9, imagem 1 %32 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 9, imagem 2 %32
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
Conclusão
Uma outra pessoa concluiu este guia.
Milton Perez
Membro desde: 03/09/17
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,711
