Ir para o conteúdo principal
Lenovo 100s Chromebook-11IBY Motherboard Replacement
O que você precisa
  1. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 3, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 3, imagem 2 %32
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 4, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 4, imagem 2 %32
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 5, imagem 1 %32
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 6, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the battery.
  8. Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: passo 8, imagem 2 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement, Motherboard: passo 8, imagem 3 %32
    • Using the black nylon spudger, lift up the grey bar of the ZIF connector attached to the motherboard located in the bottom right corner.
    • Pull out the ribbon cable connecting the motherboard to the daughterboard.
  9. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 9, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 9, imagem 2 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 9, imagem 3 %32
    • Use the spudger to coax the sliding speaker cables toward you, out of the motherboard attachments.
  10. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 10, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 10, imagem 2 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 10, imagem 3 %32
    • Use the flat end of the spudger to pop up the display cable connector from the motherboard.
  11. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 11, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 11, imagem 2 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 11, imagem 3 %32
    • Pry up the coaxial antenna cables from the wifi card with the spudger.
  12. Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 12, imagem 1 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 12, imagem 2 %32 Lenovo 100s Chromebook-11IBY Motherboard Replacement: passo 12, imagem 3 %32
    • Use your Phillips #0 screwdriver to remove six 3.7mm screws from the motherboard.
    • Use the same Phillips #0 screwdriver to remove one 3.2mm screw from the wireless card.
    • Wiggle the motherboard gently out from the case. It should come out towards you and slightly to the right.
Conclusão
Sarah Westberg
Membro desde: 03/11/19
23.125 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 866
