Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
Unlock the keyboard ZIF connector to release the keyboard flex cable.
Unlock the touchpad ZIF connector to release the touchpad flex cable.
Carefully pull both flex cables out of the ZIF connectors.
Remove the keyboard plate up and place it to the side.
Unplug the battery cable by pulling it towards the battery.
Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
