Ir para o conteúdo principal
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
O que você precisa
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 2, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 2, imagem 2 %32
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 3, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 3, imagem 2 %32
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: passo 4, imagem 1 %32
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 5, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 5, imagem 2 %32
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 1,106
