Introdução
This guide will show the steps needed to take out and replace the motherboard in the Lenovo Chromebook 100e 2nd gen. This repair is a last ditch effort to fix your broken device; only do this repair if there is significant water or structural damage to the device causing complete graphical and functional failure.
O que você precisa
Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
Use the spudger to disconnect the two ribbon cables.
Disconnect the black and white coaxial cables.
