Ir para o conteúdo principal
Lenovo 100e Chromebook 2nd Gen Motherboard Replacement
O que você precisa
  1. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 2, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 2, imagem 2 %32
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 3, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 3, imagem 2 %32
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 5, imagem 1 %32
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 6, imagem 1 %32
    • The battery is now loose and can be removed from the laptop.
  7. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Screen Bezel: passo 7, imagem 1 %32
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  8. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 8, imagem 1 %32
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  9. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the screen bezel from the laptop.
  10. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Display: passo 10, imagem 1 %32
    • Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
  11. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 11, imagem 1 %32
    • Carefully pull the screen back onto the lower assembly.
  12. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 12, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 12, imagem 2 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 12, imagem 3 %32
    • Peel back the protective tape over the display cable using the spudger.
    • Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
    • Pull the cable free and remove the display.
    • DO NOT pull on the cable before lifting the bar latch or the cable will break.
  13. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: passo 13, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: passo 13, imagem 2 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Hinges: passo 13, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
    • Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
  14. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 14, imagem 1 %32
    • Move the screen assembly perpendicular to the keyboard assembly.
    • Remove the hinges by pulling straight up.
  15. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Motherboard: passo 15, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement, Motherboard: passo 15, imagem 2 %32
    • Use the spudger to disconnect the two ribbon cables.
    • Disconnect the black and white coaxial cables.
  16. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 16, imagem 1 %32 Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 16, imagem 2 %32
    • Remove the white Lenovo sticker over one of the screws.
    • This screw conducts electricity. Remember to replace this sticker upon reassembly to avoid shorts.
    • Use the Phillips #0 screwdriver to remove the seven 3.8 mm screws.
  17. Lenovo 100e Chromebook 2nd Gen Motherboard Replacement: passo 17, imagem 1 %32
    • Slide the motherboard up and out of the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 38
Duração total: 1,600
