Ir para o conteúdo principal
Lenovo 100e Chromebook 2nd Gen Camera Replacement
O que você precisa
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: passo 1, imagem 1 %32
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: passo 2, imagem 1 %32
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: passo 3, imagem 1 %32
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: passo 4, imagem 1 %32
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: passo 5, imagem 1 %32
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 485
