Ir para o conteúdo principal
Leica Z2X Tripod Socket Replacement
O que você precisa
  1. Leica Z2X Tripod Socket Replacement, Remove the Bottom Screws: passo 1, imagem 1 %32
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Tripod Socket Replacement, Open the Back Door: passo 2, imagem 1 %32
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Tripod Socket Replacement, Remove the Bottom Plate: passo 3, imagem 1 %32
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
Conclusão
Zachary
Membro desde: 04/12/11
46 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-19, Garner Spring 2011 Membro de Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 2,471
