Ir para o conteúdo principal
Leica Z2X Lens Cover Replacement
O que você precisa
  1. Leica Z2X Lens Cover Replacement, Remove the Bottom Screws: passo 1, imagem 1 %32
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Lens Cover Replacement, Open the Back Door: passo 2, imagem 1 %32
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Lens Cover Replacement, Remove the Bottom Plate: passo 3, imagem 1 %32
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Lens Cover Replacement, Lens Motor: passo 4, imagem 1 %32
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
  5. Leica Z2X Lens Cover Replacement: passo 5, imagem 1 %32
    • Apply pressure until the piece you unscrewed in the last step pops off.
  6. Leica Z2X Lens Cover Replacement: passo 6, imagem 1 %32
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
  7. Leica Z2X Lens Cover Replacement: passo 7, imagem 1 %32
    • Removing the lens motor cover, you should be left with these four pieces.
  8. Leica Z2X Lens Cover Replacement: passo 8, imagem 1 %32
    • Located underneath these four pieces is the lens motor.
  9. Leica Z2X Lens Cover Replacement: passo 9, imagem 1 %32
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  10. Leica Z2X Lens Cover Replacement: passo 10, imagem 1 %32
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  11. Leica Z2X Lens Cover Replacement: passo 11, imagem 1 %32
    • You should now have removed the front and back plates.
  12. Leica Z2X Lens Cover Replacement: passo 12, imagem 1 %32
    • Remove the four screws holding on the front panel surrounding the lens.
  13. Leica Z2X Lens Cover Replacement: passo 13, imagem 1 %32
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
  14. Leica Z2X Lens Cover Replacement, Lens Cover: passo 14, imagem 1 %32
    • Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
    • From here, locate the three screws near the front of the lens.
    • Unscrew these three screws.
  15. Leica Z2X Lens Cover Replacement: passo 15, imagem 1 %32
    • From here, you can pull out the small disk containing the lens cover.
    • Unscrew the four screws on the back and pull the two pieces of the disk apart.
  16. Leica Z2X Lens Cover Replacement: passo 16, imagem 1 %32
    • From here, you can replace any broken parts in the lens cover.
Conclusão
Uma outra pessoa concluiu este guia.
Kenny
Membro desde: 04/10/11
57 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-19, Garner Spring 2011 Membro de Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 2,789
