Ir para o conteúdo principal
Leica Z2X Flash Diffuser Replacement
O que você precisa
  1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: passo 1, imagem 1 %32
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: passo 2, imagem 1 %32
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: passo 3, imagem 1 %32
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: passo 4, imagem 1 %32
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  5. Leica Z2X Flash Diffuser Replacement: passo 5, imagem 1 %32
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  6. Leica Z2X Flash Diffuser Replacement: passo 6, imagem 1 %32
    • You should now have removed the front and back plates.
  7. Leica Z2X Flash Diffuser Replacement: passo 7, imagem 1 %32
    • Removing the flash diffuser should be simple from here.
    • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
Conclusão
Uma outra pessoa concluiu este guia.
Kenny
Membro desde: 04/10/11
57 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-19, Garner Spring 2011 Membro de Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 17
Ao todo: 3,525
