Introdução
Prerequisite only! This procedure is part of another guide and is not meant to be used alone.
Use this guide to separate the leg assembly from the crankcase on a Wacker BS50-4AS REV 101 (2019) Vibrator/Rammer for further service.
This model requires up to 0.7 liters of SAE 10W-40 oil to replace drained oil.
O que você precisa
Firmly grip the base of the spark plug wire's connector and pull it away from the spark plug to disconnect it.
Use a 1-1/16 inch socket to break loose the oil sight gauge near the bottom of the device.
Lay the device down horizontally with the oil sight gauge facing down.
Position a shallow oil drain pan underneath the sight gauge.
Remove the oil sight gauge.
Let the oil drain until drips are infrequent.
Replace and retighten the oil sight gauge.
Flip the device onto the work surface such that the motor and handles face up.
Place two separate blocks of wood underneath the seam between the leg assembly and crankcase.
Use an 8 mm hex key socket to remove the four bolts securing the leg's guiding cylinder to the crankcase.
Continue to separate the two halves by compressing the bellows until the nylon plug covering the piston pin is visible.
Use an appropriately-sized punch and a ball-peen hammer to tap the pin out of its hole on the guide piston until it is no longer securing the connecting rod.
Use a punch and hammer to tap the pin out of the guide piston.
