Ir para o conteúdo principal
Leapfrog LeapPad 3 Motherboard Replacement
O que você precisa
  1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement, Battery: passo 1, imagem 2 %32 Leapfrog LeapPad 3 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Motherboard Replacement: passo 2, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 2, imagem 2 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 2, imagem 3 %32
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Motherboard Replacement: passo 3, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 3, imagem 2 %32
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  5. Leapfrog LeapPad 3 Motherboard Replacement: passo 5, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 5, imagem 2 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  6. Leapfrog LeapPad 3 Motherboard Replacement: passo 6, imagem 1 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 6, imagem 2 %32 Leapfrog LeapPad 3 Motherboard Replacement: passo 6, imagem 3 %32
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
Conclusão
4 outras pessoas executaram este guia.
Matt Irvine
Membro desde: 02/04/16
952 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 16-2, Blackwell Winter 2016 Membro de USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
Membros da 3
Autoria de 12 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,450
