Introdução
This guide will require removing the case as well as unplugging several components and removing the mother board as a whole.
O que você precisa
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
4 outras pessoas executaram este guia.
