Introdução
If your display assembly is scratched or not working properly this is the appropriate guide to get the issue resolved. It is a rather lengthy, however, it is complete and few tools are needed.
O que você precisa
Vídeo de Apresentação
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
5 outras pessoas executaram este guia.
4 comentários
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
