Introdução
To replace the battery you will need a replacement. Once you have the battery, following this guide will lead you to a fully functioning device.
O que você precisa
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
3 outras pessoas executaram este guia.
Um comentário
where can i purchase a battery, i have googled and come up with nothing.
