Ir para o conteúdo principal
LeapFrog Scribble and Write Motherboard Replacement
O que você precisa
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: passo 5, imagem 1 %32
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the volume control switch from the motherboard with the soldering iron.
Conclusão
Uma outra pessoa concluiu este guia.
Shang
Membro desde: 02/10/16
328 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-5, Nance Spring 2016 Membro de USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 641
