Ir para o conteúdo principal
LeapFrog Scribble and Write Eraser Slider Cleaning
O que você precisa
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: passo 1, imagem 1 %32
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 3, imagem 1 %32
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 4, imagem 1 %32 LeapFrog Scribble and Write Eraser Slider Cleaning: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 5, imagem 1 %32
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 6, imagem 1 %32 LeapFrog Scribble and Write Eraser Slider Cleaning: passo 6, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: passo 7, imagem 1 %32
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Conclusão
Shang
Membro desde: 02/10/16
328 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-5, Nance Spring 2016 Membro de USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 948
